Hopefully you shouldn't need much epoxy, where you need to fill anything over a few tenths of a mm you could put glass fibre cloth in the space. It will be better to use a thixotropic or fairly viscous variant than the west system stuff which is designed to wet out composites and is a pretty thin liquid. I don't think you need to worry too much about bonding if it's trapped in a clamped interface - using epoxy to actually make the join is another matter and you would need very good surface prep and glue / material selection in that case.
I've a length of 3" square 1/4" wall aluminium that I'm intending making my router out of but I haven't had chance to do any measuring on it. I'm hoping it will be close enough that I can just use a thin layer of epoxy on the interfaces and by initially clamping the rails down very lightly until the epoxy sets ensure that they are not deformed by the box section. It'll be at least a couple of months before I get to that stage so I'm looking forward to reading how you get on
06-09-2010 #2
06-09-2010 #3
Box section tube straightness
By jimbojones1000 in forum Metalwork DiscussionReplies: 7Last Post: 18-02-2014, 04:11 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Help with name of aluminium section plz
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 02-12-2012, 10:01 PM -
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
spindle cross section view
By routercnc in forum Tool & Tooling TechnologyReplies: 20Last Post: 05-08-2011, 12:55 AM
