Thread: Heiz T-1000, early impressions.
02-03-2011 #24
It could be a defective switch although if it is showing as active in the signals test, then it would be an intermittent fault - which would be unusual in a solid state hall effect unit. If you have a magnet handy, move the gantry away from the switch, set the machine for signals test and move a magnet close to the switch.
Other things to check :
1) All cabling. Check that the signal plugs into the controller are good.
2) Reference Speeds. Assuming the switch is good, what are they set at? Does reducing the homing speed make a difference?
3) The magnet has become degaused. Unusual but it can happen if they are knocked or for some reason heated up.
There are currently 18 users browsing this thread. (0 members and 18 guests)
Doris CNC - early feedback appreciated
By woodspiral in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 08-06-2014, 10:57 AM -
Best CNC Lathe for £1000?
By Ratch in forum Marketplace DiscussionReplies: 2Last Post: 19-10-2013, 01:45 PM -
RFQ: Early enquiry
By boldford in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-07-2012, 06:40 PM -
NEW MEMBER: New member looking to get a T-1000
By ASZUCS in forum New Member IntroductionsReplies: 1Last Post: 08-12-2010, 01:39 PM -
NEW MEMBER: early stages
By dopamine in forum New Member IntroductionsReplies: 1Last Post: 04-12-2010, 01:33 PM
