    My 500th post on this forum :surprised: ... something a bit different.
    A few months ago I started making a 4th axis for my milling machine, or router. My reason for doing this is to have it belt driven, thus faster than the vertex rotary table I converted and capable of being used as a lathe. This is the original design:
    It includes solenoids to make a disk brake which should mean I can get a much higher holding torque than with the stepper motor alone when stationary.
    I machined the shaft and bearing housing at school since they were much to big for my mini lathe, and CNC milled all the slots for the solenoids using the rotary table. The hole through the spindle is 1". I press fitted the tapered roller bearing outer rings.
    Recently I got round to making and fitting the timing pulley so I thought it was time for a test. I've not made the mount for any motor yet, so I just used the large brushless motor I'd converted to a spindle, put a pulley in its chuck, and stuck it in a vice. Crude, but it works for now. Shown below is it set up to machine the front of the spindle, the same as my C3 lathe, to fit the chucks I have. I left this bit until last since machining this in place should minimise the runout:
Name:	DSC07171 (Medium).JPG
Name:	DSC07174 (Medium).JPG
    Spindle after machining:
Name:	DSC07172 (Medium).JPG
    The motor, though only run on 24V from some big batteries - not the 48V that it is rated for, and geared for 2900rpm works well at the much lower rpm required to machine the face of the spindle which is 80mm diameter.
    At the moment my method for mounting the lathe tool is distinctly dodgy. Not surprisingly it vibrated a fair bit. At some point I shall make a proper tool-post that bolts onto the milling machine somewhere else, not to the quill.
    Just as a test I tried machining a 22mm diameter hemisphere onto a piece of aluminium bar, and a similar size hemisphere on to the end of a 20mm diameter mild steel bar. I will upload the videos shortly, here's some pictures of the result. Not great, but it's hardly surprising with the way the tool was mounted and the tool I used:
Name:	DSC07193 (Medium).JPG
Name:	DSC07189 (Medium).JPG
Name:	DSC07188 (Medium).JPG
    The next stage for this is to make the motor mount incorporating brushless and stepper motor and probably a dual timing belt reduction to get around 10:1 ratio for the stepper motor. Then I will add the solenoids, if necessary.
    Here's the video:
    splendid !! i like it, iv opted for the harmonic drive so there'll be no turning on mine but im well chuffed with how well it works... i should get a vid up to show it off :)
    where the hell do you find time to go to uni ???? youll fail all your exams but be a top notch engineer :)
    Just realised I've forgotten to reply to this
    Where did you get the harmonic drive / which one? Please do put photos up! A harmonic drive looks like a great way to do a B/C axis to rotate the spindle - something I would like to do on my router once I've made the sturdier frame.
    :heehee::heehee:
    howdy jonathan, i stalked ebay for months to get this harmonic drive... think i paid about £110 for it, it was in mint condition...i think it was pulled from a prototype that didnt quite come to anything and was a costom order from LLC 60:1 ratio (strange)
    iv just rendered out a video with it in, ill try to post it up on the forum in a mo, itll give you an idea of what i did :)
    hay Jonathan that's pretty good mate.
    Yes ... it works. It would be much better if I made a proper toolpost. At the moment the setup is very limited due to the clearances round the spindle.
  1. Replies: 19
    Last Post: 21-08-2013, 11:20 PM
  2. FOR SALE: Clarke CMD300 / Sieg X2 3 Axis Milling machine CHEAP
    By craigrobbo in forum Items For Sale
    Last Post: 28-07-2013, 07:54 PM
  3. axis not moving when running code
    By geny in forum Computer Software
    Last Post: 21-10-2012, 08:02 PM
  4. Running 4 axis from a ps806 or sps705 psu
    By jonbabbz in forum General Electronics
    Last Post: 14-07-2012, 09:50 AM
  5. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
