Thread: motors on which end of screw
Yep STD in my world means Standard.! As in STD Deep grove bearings.
Believe the screws are the ones you sold him so you should know best which they were machined to use.?
Thou to be honest I was just trying to make him aware one end needs to be fixed with a simple example of a cheap way to do it. . . .(Knowing because I cut some bits for him that they didn't look like they were designed for 2 bearings.? )
13-10-2011 #2
Thought it might be those. Have a look at the first post in my build log to see how I did the shorter screw with a single thrust bearing and 'STD' bearing:
http://www.mycncuk.com/forums/showth...outer-building...
I did the Y similarly but with two thrust bearings. Easier to use double row angular contact. Didn't I include some bearings / mounts with it? I forget...
13-10-2011 #3
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM -
FOR SALE: Screw & Nut for Z axis
By phill05 in forum Items For SaleReplies: 0Last Post: 12-06-2010, 05:12 PM -
New build - Screw specification???
By HiltonSteve in forum Linear & Rotary MotionReplies: 25Last Post: 21-05-2009, 08:47 PM
