Thread: Diy Brushless Spindle
	26-10-2011 #21a man after my own heart :)I was going to get them and then spend the time whilst they wing their way from the US looking at ways to do it :-)
thats more like it :) if you over size the bore just slap a bit of epoxy in there it should easily take the cutting force (just dont use your posh bearings on that one lolI might buy a 50mm dia offcut of Ali and have a tinker on the lathe at work, will check to see if we have any boring tools to play with!
	26-10-2011 #22
Just bought 2 off 2" dia x 50mm bits of Ali.....one to mess about with and the other to do the propper job :whistling:
I'd best get started then as just been informed that they've been shippedI was going to get them and then spend the time whilst they wing their way from the US looking at ways to do it :-)
	26-10-2011 #23hahahahahaha!!!!!! i think me n you might have been separated at birth :rofl:Just bought 2 off 2" dia x 50mm bits of Ali.....one to mess about with and the other to do the propper job :whistling:
	27-10-2011 #24
Well they say you're supposed to measure twice, cut once........never works for me :confused: so I get twice what I need and mess the first one up :naughty:
	27-10-2011 #25
	27-10-2011 #26
Cheers John, when you know what they're called they're everywhere!! Still got to work out how to shield them.......
	27-10-2011 #27
Hmm, I even looked there... must be blind:
http://www.arceurotrade.co.uk/Catalo...-Ball-Bearings
Aluminium disk or whatever with only a very very small clearence - enough to stop it touching, but not so big that it lets lots of dust in. I believe the term is aluminium labyrinth. Any seal which touches is going to generate a lot of heat due to friction.
	27-10-2011 #28
Or...
http://simplybearings.co.uk/shop/p42...duct_info.html
or...
http://www.ebay.co.uk/itm/E8-MAGNETO...item2eaeaac383
etc.....etc...
Was going to see if I could reverse engineer a shield like on the 608RS bearings....or how about http://simplybearings.co.uk/shop/p24...duct_info.html but not sure what speed it's rated to....food for thought anyway!Aluminium disk or whatever with only a very very small clearence - enough to stop it touching, but not so big that it lets lots of dust in. I believe the term is aluminium labyrinth. Any seal which touches is going to generate a lot of heat due to friction.
	27-10-2011 #29
Yes, easy once you know...
I doubt rubber seals are appropriate for the speed this will be running at. The bearings apparently already get hot, so a seal like that is just going to make it worse. I used some on my wind turbine, for each blade, and they add a lot of friction...but it didn't matter there as it's only a few rpm.
	27-10-2011 #30
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
