The brain approch would work perfect for this because you won't need to do anything inside the G-code, It will just monitor the Z axis and activate/deactivate the pin at the correct height.
While watching I could hear an air solenoid firing then read that he use's a pnuematic dispenser connected to a 555 timer and 3 way valve to control over dispense. The Brain and Mach could be made to act as the timer but how would you control over dispense.?
26-12-2011 #2
My pneumatic dispenser can either be set to auto (in which case the length of 'dispense' time is controlled by a pot on the dispenser - triggered by a footswitch - or a relay under g-code control), or manual in which case it is controlled by how long the footswitch is held down. (or again a relay uinder g-code control). In other words the amount of dispense could be set by the dispenser itself or else by how long the g-code paused between on & offs.
Where it gets a little wearying is that for example, a SOT23-3 pad doesn't need anywhere near as much paste as a PLCC2 LED per pad. Therefore it'd need a bit of sorting pads into different 'dispense' runs.
If I had enough grasp of coding geometry then I could have an eagle ulp do this pad sizing decision for me....but I haven't so manual it is for now!
mounting profile rail - Hiwin Manual vs. typical approach
By dsc in forum Rails, Guideways & BearingsReplies: 14Last Post: 11-12-2013, 10:43 AM
