Have you used the dispenser before.? Like the guy in the Vid I would think you will need a pressure dump other wise the airline and cyclinder will still be under pressure so seepage could happen.
Regards the different pads amounts then this would be done using the G4 pause command. It could maybe done using the tool numbers.? So T1= Sot23-3 and T2=PLCC LED and so on. . . . . . . . . . . Then I don't think it would be to hard to write a script that reads the code and looks for the T number value then changes G4 P value to time required for that pad. Little like replace in note pad but more controlled.
Edit: Actually thinking about it.!! . . I bet If you altered or built a purpose post processor then it could insert the correct time into G4 P value.?Last edited by JAZZCNC; 26-12-2011 at 03:48 PM.
mounting profile rail - Hiwin Manual vs. typical approach
By dsc in forum Rails, Guideways & BearingsReplies: 14Last Post: 11-12-2013, 10:43 AM
