Thread: Pre-RFQ Design
Also if you are looking at bending aluminium you would need to heat it or it will crack.
05-02-2012 #2
Yes, put some soap on where you need to anneal it for bending then heat it. When the soap goes black that's the right temperature for annealing, so allow it to cool. I've done that with aluminium and 1/4" becomes soft enough to bend by hand once annealed, although it will depend on the grade.
How much does the TV weigh?
05-02-2012 #3
05-02-2012 #4
05-02-2012 #5
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
CNC Design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 23Last Post: 20-09-2010, 03:25 PM
