Thread: New to MyCNCuk
27-03-2012 #4
Really you should look to get the resolution you want from the pitch of the screw not the drive stepping. Higher Micro stepping(10x Max) does help but more for motor smoothness than resolution.
What you need is a low pitch ballscrew say 4mm or less, I recommend you don't try the cheap route and use threaded rod or cheap Acme screw and nut.!!
Because of the nature of what your wanting to do you'll need repeatabilty has much as resolution and threaded rod and cheap Acme which usually come with rubbish nuts which just can't give you what you'll need.
How about a mycncuk cnc router project?
By GEOFFREY in forum Open Source Designs & PlansReplies: 117Last Post: 02-05-2015, 07:38 PM -
NEW MEMBER: newbie to mycncuk
By kelef in forum New Member IntroductionsReplies: 0Last Post: 20-03-2011, 07:42 PM -
NEW MEMBER: Hello MyCNCUK
By Jimmybristol in forum New Member IntroductionsReplies: 3Last Post: 07-01-2011, 04:44 PM -
NEW MEMBER: Learning with MYCNCUK
By Goran in forum New Member IntroductionsReplies: 1Last Post: 10-12-2010, 06:08 PM -
NEW MEMBER: New to MYCNCUK
By John Ferguson in forum New Member IntroductionsReplies: 6Last Post: 09-03-2010, 08:07 PM
