Eunji doesn't mind too much, she just wants me to sell lots! She is very understanding about hi-fi stuff too since she works in music. Actually she is very helpful in blind testing stuff since she did 3 years of critical listening training.
Just for fun, a quick photo of the table in the living room right now, lol.
Ooooh that is nice! I don't think it will save alot of space for me though because the gantry height, plus z-axis motor and machine frame end up about 65cm, and the width is only about 85cm. I think I'd prefer easy clamping. That said, I could easily turn the machine on it's side if I want.You can build in a cover and have it vertical. Its more work in the design stage but can make for a really neat machine when space is an issue(when isn't it?). If I'd DIY'd I'd have likely done something very similar to this:
http://www.denfordata.com/pdfs/produ...cal-router.pdf
Very tidy package that would easily allow for a 4x4ft bed. All the crap falling into a pan at the bottom rather than all over the workpiece or into you rails etc. is another plus. Really there's not many downsides aside from increased build complexity and more awkward clamping. You could add vacuum bed later to solve the latter.
If your spending the sort of money I think you are then its worth considering.
All the router bits I have are 6mm shank, and I have a fair bit of money in that. I also thought it was possible to just buy an ER20 collet... nevermind!
Good stuff but the ER16 collet might be a bit limiting. Can I ask why you choose that over the ER20? I looked around long and hard at cutters and most of the extra long series cutter are 12mm shank. These cutters allow thick(ie. 100mm) baffles to be safely machined.
So are you doing custom built speakers professionally now?
I still need to have a go with Acourate!Last edited by Tenson; 29-03-2012 at 11:33 AM.
29-03-2012 #2
Tenson that looks like my front room, my wife reckons it won't be long till I've got it looking like delboys flat in only fools and horses. Minus the inflatable dolls of course ;-)
I wonder if we should start a thread on "How diverse are the things that we make?" That could be an eye opener! Got a few good ideas of my own.
29-03-2012 #3
Looks familiar :)
The gantry is offset by you being able to go upto 4x4ft. Generally a 4x4 will stick out at least 1400mm from whatever wall its pushed up against. Vertical would be less than half that.Ooooh that is nice! I don't think it will save alot of space for me though because the gantry height, plus z-axis motor and machine frame end up about 65cm, and the width is only about 85cm. I think I'd prefer easy clamping. That said, I could easily turn the machine on it's side if I want.
When you say router bits do you mean the regular 1/4" collet types with straight flutes? They'll work fine but you might want to consider getting yourself some end mills. These are generally better quality, plunge much better, remove material better and last longer.All the router bits I have are 6mm shank, and I have a fair bit of money in that. I also thought it was possible to just buy an ER20 collet... nevermind!
Use up what you've got and once they're starting to dull get yourself something like these:
http://www.ebay.co.uk/itm/1405488812...ht_3253wt_1163
They're really cheap for what they are and were recommended to me by folks like Jonathan and Jazz who've used them to cut aluminium. They'll eat MDF and ply for breakfast and last ages.
Pretty much but nothing official. Its mostly word of mouth but I hope to bring a small lineup of speakers eventually. There's a lot of planning involved before that can happen not to mention prototypes, listening tests, crossover tuning, auditioning. I had hoped to have a floor standing speaker available before the end of this year but I've recently taken on a custom project for Arthur(Ackcheng on DIYA) over in Hong Kong and its scale is very ambitious. A total of 8x 10" drivers, 4x 8", 4x 5" and a pair of ribbons all housed in 2100mm x 320mm x 750mm cabinets. Its the audio equivalent of the Deathstar.So are you doing custom built speakers professionally now?
And last year I designed(not built) a huge OB dipole line array with seperate ripole sub stacks for a guy in New York. 8x 21", 18x 8", 16x BG Neo10's and lots of Mundorf AMT's. I believe he's now taken the CAD files to various machine shops in the US and is in the process of having them manufactured. Materials are alu and acrylic and the project is about the cost of a new mid range Benz.Last edited by Shinobiwan; 29-03-2012 at 03:26 PM.
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
