18-04-2012 #6
Yes - the load rating of the bearing blocks varies depending on the direction of the applied force. In other words if the force is in the direction attempting to pull the bearing off the rail clearly the deflection will be greater. For that reason it's best to mount them so the rail supports are facing each other. This evens out the deflection, so you effectively have medium deflection all round instead of large deflection when cutting one way and small deflection the other way.
BUILD LOG: This is my first BUILD please help.
By DigiSoft in forum DIY Router Build LogsReplies: 60Last Post: 27-01-2016, 04:37 PM -
Add-on CNC build log
By bikepete in forum Milling Machines, Builds & ConversionsReplies: 23Last Post: 06-02-2013, 03:02 PM -
Build or buy?
By jonnydeen in forum Machine DiscussionReplies: 6Last Post: 13-05-2012, 11:01 PM -
Just a tip for anyone looking to build CNC
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-07-2010, 06:08 PM -
BUILD LOG: my build
By jonm in forum DIY Router Build LogsReplies: 54Last Post: 22-04-2010, 10:14 PM
