Thread: Chinese Spindles
Money isnt really a problem to be fair, i just want the best value with what i spend, and if that means submitting designs to engineering companies to have the things custom made then so be it, on the other hand im not sure i want to spend £2000 when i cant help thinking there must be a cheaper way..... after all this forum is full of people with mills and routers isnt it
25-05-2012 #2
Yes I get what your saying and this is my point.! To do it correctly and be worth the trouble it won't be any cheaper I don't think. Custom made anything cost's money.!!
This is my take on it.!! . .The chinese WC spindles in there current format are not really suitable to ATC for both the spindle taper type and the fact they are high speed low torque motors.
To design one based on the current WC spindle will require much trial and error and at £180 pop and quality angular contact bearings etc you don't need to get it wrong many times to start building up the costs.! . . . . If you did manage it then IMO you would still have a less than ideal ATC setup.!
If moneys no object then go for it and I know I'll be watching with great interest.!
If you want an idea of the work involved in building a proper ATC spindle then checkout Henriks thread on cnczone and he still wasn't 100% happy with it when finished because it had 0.01-0.02mm runout.!! . . . He's bit of a perfectionist thou.!
http://www.cnczone.com/forums/vertic...roject-13.html
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
