Page 7 of 13 FirstFirst ... 56789 ... LastLast
  1. Try theses http://www.spnd.com.tw/prod-e.html company called micro lab in taiwan, i had a quote last year for a M3-FPS Belt driven spindle that could run at 10K and that was $1000 these look very good quality units. they also do a load of other style spindles but again price is a big contender here!
  2. #62
    Oooo thats a posh site.. and has some real goodies on it but i cant see any real spec sheets or a price list...
  3. #63
    i2i's Avatar
    I would like 1.5 - 3hp motor, 6000 rpm, bt30 atc with grippers, all in one motor/spindle package if poss.
  4. #64
    Quote Originally Posted by i2i View Post
    lol me too
  5. #65
    I think it's a safe bet to say Jazz and I would only be interested in the 15000rpm, BT30 spindle:
    http://www.spnd.com.tw/pem3-fps.html
    Realistically I just can't afford one, but lets see what the price actually is first... Also could do with getting a drawing from them.
  6. #66
    I bet once you pass 10k the price goes up as much as the rpm..... lol but it would be nice if it had a motor on from where i sit, as i will have to buy one anyhow and im sure that wont be cheap.
  7. #67
    i2i's Avatar
    it may be difficult to get a "low" rpm (6000rpm) spindle with the motor fitted.
  8. #68
    Build one.
    This one is only 1,5Kw, 2HP and ER32 but everything is adaptable.
    John S -
  9. Quote Originally Posted by John S View Post
    Build one.
    Absolutely
    There is one which I build. It takes MT3 ER20 collet chuck or anything with MT3. It's not final design, but gives idea how it will looks like. There will be MT3-like taper on the top to install set of reduction pulleys. I rather needs to go down with the speed than up so taper roller bearing will be perfect for this.
    So far hollow shaft including M30/1 thread for preload nu,t internal and external MT3 tapers is turned. I'll try to make some pic of it.
  10. #70
    Im sure it will, but to be fair, the more time goes by, the more likely i am to just buy the 10k ATC spindle and sort the motor seperatly. It seems od to me that so many people have these things but nobody knows where to get them at a reasonable price..lol
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  3. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  4. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
  5. NEW MEMBER: Spindles
    By Johnp in forum New Member Introductions
    Last Post: 28-06-2009, 11:46 AM
