Thread: Wood Router
28-05-2012 #6
Incorrect priorities.
A heavy gantry (and machine in general) is good since you want to have as much strength as possible. Making cutouts, including the ones you have already drawn, just wastes strength and money. Rigidity is far more important than feedrate. If you're reducing the mass to improve the feedrate you're going about it the wrong way - you should select the motors and drivers to get the feedrate you require which, as Jazz said, means buying 70-80V drivers such as the M752. Bear in mind the stepper motor output torque at high speed is roughly proportional to the applied voltage, so going from 45V to 75V is a 67% gain in torque where it matters.
My new 4 axes wood processing CNC router...
By florins in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-12-2021, 10:42 PM -
Wood cnc router for hobbyist
By nerostjames in forum Machine DiscussionReplies: 9Last Post: 01-01-2018, 09:28 PM -
wood sign cut with cnc router
By jonm in forum Woodworking Project ShowcaseReplies: 5Last Post: 09-06-2014, 08:05 PM -
BUILD LOG: Wood router machine, 600x400
By troyboy1 in forum DIY Router Build LogsReplies: 2Last Post: 05-12-2012, 12:47 AM
