Thread: routing aluminium help :)
04-06-2012 #11
From my experience with cutting aluminium I believe coolant and amount of coolant is very important. It is not only cooling factor, but chips removal and lubrication as well.
I use plain diesel, strait from petrol station as a coolant. It's cheap, available, does not cause corrosion and it is not likely to get bad. In fact it protects my machine against rust.
As an example, to cut my aluminium plate for my PC cooling system I used 4 flute HSS 3mm dia end mill available from UK online shop. There was no clogging and broken end mills at all. I don't remember feed rate and DOC( it was few yars back), but most certainly I wasn't creating alu dust.
Obviously using two or single flute carbide bit would be advantageous, but milling in a way I did proves significance and necessity of coolant.
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
NEW MEMBER: New to cnc routing and looking to buy a machine.
By stamper in forum New Member IntroductionsReplies: 3Last Post: 03-12-2011, 03:31 PM -
PCB Isolation Routing
By Mad Professor in forum General DiscussionReplies: 3Last Post: 16-03-2011, 09:46 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
