Thread: LM Rail
    Price for the blocks is about normal:
    http://www.wmh-trans.co.uk/Products/..._BLOCK_SIZE_25
    At the same place 1m of rail is £65+vat. Where did you get those prices?
    I am getting mine from East Europe just like other components that are cheaper, some of them are about 50% of a price of UK suppliers.
    Quote Originally Posted by vigen20 View Post
    Hi vigen, where about do you get your THK rail from. As I was looking for a pair of LM rails approx 1500mm long suitable for SHS25 bearing blocks and similar length pair of rails suitable for SHS20 bearing blocks.
    Jim
    Hi GTJim
    http://stores.ebay.co.uk/FA-SYSTEM_L...34Q2ec0Q2em322
    As posted in another thread a while back I've bought a couple of used profile rail and bearing sets from the above link. Been happy with the service and component quality. These are all used, hence the fairly reasonable prices.
    If you are patient on ebay you may find cheaper, but if you want to get on with it then have a look through their store.
  4. The Following User Says Thank You to routercnc For This Useful Post:
  5. #4
    Quote Originally Posted by chip View Post
    ive took a chance and bought some used rail off him sr15 for my y and z,just need the right lengths for my x axis to come up and im on my way..
    Should have waited and bid on it...his prices are OK but you'll do much better by bidding, unless you're really tight for time. What length rail did you get for Z?
  6. #5
    yes i should have waited,too impatient ,im not even sure it will be up to the job, i bought a little over 400mm for the z and about 1200mm for the y with the mind to cutting it down if need be as i still cant committ to a size of machine or design.
    Don't cut it - use the extra length to space the bearings out further. Normally the force on each bearing is inversely proportional to the spacing, so you want to space them out as far as you can (within reason, assuming what they're mounted on is stiff) to reduce the load on each and thus reduce the deflection. I got two 1150mm (hiwin HGH15) rails for my Y-axis, which is only 760mm travel but I wont be cutting the rails.
    ive only managed to find 1 working machine using it on his z and y axis,great little machine but he has 4 lengths of sr15 on his y axis alone.
    He's probably used 4 as unlike most of the good rails the SR series does not have an equal load rating in all 4 directions - http://www.thk.ru/cataloguespdf/sr-300e_cc.pdf ... but since you've already bought them I wouldn't worry about it - any profile rail is going to be a huge amount more rigid than the SBR20 rails you currently use.
  7. The Following User Says Thank You to Jonathan For This Useful Post:
  1. DIN rail and fittings suppliers
    By Neale in forum Marketplace Discussion
    Last Post: 19-05-2014, 10:14 AM
  2. Tsk profile rail preloads?
    By totts in forum Rails, Guideways & Bearings
    Last Post: 19-04-2014, 07:44 PM
  3. WANTED: Supported rail. The bigger the better
    By r0bsk1 in forum Items Wanted
    Last Post: 08-07-2013, 07:50 PM
  4. Open Rail, open source linear rail?
    By Musht in forum Open Source Designs & Plans
    Last Post: 15-06-2012, 12:21 PM
  5. Supported rail or other?
    By lateAtNight in forum Rails, Guideways & Bearings
    Last Post: 14-11-2008, 02:28 PM
