Thread: Strike CNC (My first CNC router)
Thanks for the help.
The stepper cables are shielded and ground at the control box end.
I'll try changing the current to what you suggest. The motors still made the same noise with the default setting of 1A before I changed it to 3.93A so no damage done to the motors.
Will play around some more this afternoon based on whst you've suggested.
11-07-2012 #2
OK, make sure that the rotary switch is in the "0" position.
Set the current to 3.6A and then power up.
Then move SW4 on and off twice to get the driver to tune to the motor specs.
Once this is done it should work ok.
Make sure the signal cables are not close to any power cables.
When you power the driers up, did the inverter for the spindle power up? if so disconnect it.
Visit Us: www.automationshop.co.uk
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Strike CNC
By GMCNC in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 08:06 PM -
Your Opinion MK2 .. STRIKE CNC machine
By PWD in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 25-05-2012, 03:49 AM -
Strike CNC
By Strike CNC in forum Manufacturer NewsReplies: 0Last Post: 15-02-2012, 10:35 PM
