The back plate is there because otherwise the Y-bearing mount plates are effectively cantilevered, hence in my opinion it's worth having something to reinforce these joints. However I agree that plates on the sides, as you suggest, would offer much better reinforcement, but this would increase the width of the Z-axis and loose some travel on Y, assuming the width of the Z-axis has already minimised. The plate certainly doesn't need to be the same thickness as the other parts, it was just convenient for the one in post #20 since I didn't have much of anything less than 20mm in stock, plus it was an easy way to support the motor mount.
Iwant1: How far are you with the design / build now?
11-08-2012 #2
Not really much of a cantilever is it at 1 or 2mm and still your not supporting the cantilever but have created double cantilever ~(see-saw with bearings as pivot.!) with no bracing support.!!
Plate thickness doesn't matter could be 50mm or 5mm it's still adding very little vertical bracing support.? Plus it restricts the back side of the gantry so cable chain etc is more difficult to run.? . . . Like say IMO it's heavy, expensive, restrictive and unnecessary. . . Each to there own.!!!
11-08-2012 #3
Lots of changes have been made, its an ongoing process with every new thread on here, regarding motor drives and the strongest gantry designs. It gets so confusing. So far, I've managed to sell off my supported round rails and have already bought profiled rails for all axis, got a good price so went with 20mm. I also sold my 50v power supply and got a 2x24v toroidal coil from which I will build my 70v supply. And now I'm thinking about selling my pm752's for the digital am822's. I Know I know, I should have waited before I bought all the wrong components, but at the time, 2010, these were the most popular components. 2 years later I now want an even better machine than I originally thought of.
Anyway, I've also been busy buying all the electronics for my control cabinet. I will be using an old pc case, and filling it with goodies. Around £300 have been spent on all the electric bits, including screened cables, regular 16/0.2 cables, e-stops, limit and homing switches, relay gear, toriodal coil and electronics to rectify it, 12v and 24v psu's, small consumer unit, a selection of plugs and sockets, and the list goes on.
Chai a even sorted me out with a good price for a 2.2kw spindle and vfd, so I went and got some cooling components for this too. Mainly, a water pump with reservoir, double aluminium heat exchanger, 2 120mm pc fans and grills to go with the exchanger. Once these bit arrive, then I will see what size pvc hose I need.
I've been taking pic's of the control cabinet getting made and will post soon.
Adil
11-08-2012 #4
11-08-2012 #5
Limit switches are quite small and can be put in most place, on the frame or moving parts like the gantry or z axis. I bought the regular small lever micro switches by Omron not the cheap unbranded ones.
But the homing switches, if you use good ones can be around 50mm x 50mm and 20mm thick, quite large. Again I went for Omron and got a good deal on ebay
The Following User Says Thank You to Iwant1 For This Useful Post:
11-08-2012 #6
CONVERSION: Re-Built a used CNC mill machine to the point of 80%
By dudz in forum Conversion Build LogsReplies: 13Last Post: 20-03-2014, 06:44 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
