    Hi..thankyou for your reply...Im not needing to make 100s of letters a day probably 10th0 a week perhaps..I ideally wanted to start both something small and upgrade at a later date..its only a small business run by myself alone. unfortunately I wouldntt have a clue where to start making one, did think about it, but spending all that money on building something have no clue about is too worrying.
  2. Quote Originally Posted by kemo_2002 View Post
    ...probably 10th0 a week perhaps..
    Was that 10 a week or 100 a week?
    If the letters are 6"/150mm high on 11mm MDF and you are talking abut low run rates then if you started with a small blank precut say 170mm x 170mm you'd get 98 letters out of a sheet of MDF with <5% wastage. You could get B&Q or whoever to precut these blanks for a small sum about £10. In that case you could get away with a much smaller/lighter/cheaper machine around £500 - 600 new or even less if you picked up an ebay used bargain. You could even build a suitable machine for that sort of work from MDF for £300 or so, to an existing established design, which for someone with your evident hand-working skillls should be relatively straightforward.
    While obviously cutting from a full or half sheet of MDF is preferable from a speed/materials cost/job run perspective (especially if you were doing a 100 a day!) its something you could then aspire to as the business develops, by which time you'd have the knowledge/skill to make the more complex decisions about specifications and whether to buy/build.
    Heres an example of what you could buy (not suggesting you get this one, before Jazz leaps in lol) http://www.ebay.co.uk/itm/Sable-2015...item3a791045f0
  3. The Following User Says Thank You to irving2008 For This Useful Post:
  1. Cutting metal shapes
    By jmac80 in forum Metalwork Discussion
    Last Post: 27-11-2013, 10:32 PM
  2. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  3. RFQ: Small wooden parts
    By Tabclear in forum Projects, Jobs & Requests
    Last Post: 01-03-2013, 05:46 PM
  4. wooden joints
    By luke11cnc in forum Woodwork Discussion
    Last Post: 18-10-2012, 11:59 PM
  5. newbie need advice on cnc machine to purchase? routoutcnc machines any good?
    By wyndham in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2011, 08:54 PM
