Thread: Gantry design question
06-10-2012 #3
Thanks for the reply, I was looking at carbon fibre precisely because of concerns about vibration, CF is insanely good at dampening that and a CF honeycomb panel won't flex at all until you stress it enough to induce catastrophic failure like when an F1 car meets concrete at 200 mph or the four horsemen of the apocalypse ride into town after a bad day at the office. It's why the 'budget no limit' aerospace & motor sport guys use it.
Is the extra mass adding momentum that helps the cutting process, or is it just eliminating vibration? Given the number of minute and rapid changes in direction a CNC machine must go through it seems counter-intuitive to add mass but I really do know nothing about CNC... (Damn it, where is the 'clueless dimwit' emoticon when you need it!) I kept coming back to that design direction especially after reading papers like this:
http://www.iaeng.org/publication/WCE...p1941-1947.pdf
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM
