Thread: Gantry design question
06-10-2012 #5
You are right, I stumbled across that while trying to find papers on the use of honeycombs or CF, there seems to be remarkably little available to be honest I was more taking away the general principle of 'honeycombs good if used correctly' rather than the specific application they refer to.
CF is brittle and really sucks for friction that's true, but every material has it's limitations hence why we don't use rubber for roof suporting girders. That said, it is a bit worrying that nobody else is doing it, I don't know if it's because it is a really stupid idea or because I'm a genius and smarter than an entire industry full of inteligent professionals. ( I vote for it probably being a stupid idea!)
Hmmmmm.
I think maybe the best thing to do would be to design 2 gantrys, if I can get the cost difference down to £50-£100 I might take a punt just to see what happens. I was orignally intending to epoxy the surface fittings on but if I bolt through the structure instead if it all goes horribly wrong I should be able to fix it by adding a couple of thick reinforcing sheets. ( I'll engrave one with 'JAZZ WAS RIGHT!' if I do just to remind me what to do with my next good idea.)
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM
