Thread: Gantry design question
06-10-2012 #6
Interesting paper, but the structure they refer to in there, if I understood it correctly, is actually a support column not the moving gantry itself. While the paper starts off talking about the gantry all the study work is on the column design. So the jury is still out on whether a lightweight CF gantry beam is better. However, the information is useful as regards the gantry supports. The issue however, is for the small sizes we generally build, i.e. a gantry side 300 - 500mm high or so, does the complexity of forming such a structure give any benefit over a slab of 20mm ali?
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM
