    Hi Jonathan,
    Thank you for the reply ! :-)
    I use the 2M880N Microstepping Driver from Zapp and the stepper is a 3Nm I got from a Boxford CNC mill a while ago...
    Not a bad price at all! The servos, do they come with encoders ?
    Also, I see they have motors with DC brakes ? What are these for ?
    Laurent
    Quote Originally Posted by rnr107 View Post
    Yes they come with quadrature encoders, standard 2500.
    To stop the motor moving when the power is switched off, which is useful if for instance the motor is running a Z-axis which could drop with no holding torque. The brake is rated for slightly greater than torque than the motor, so it's not much use as a spindle lock unfortunately.
    OK, What about Mach3 control ? Do the drivers come with DIR & Pulse inputs as stepper drives or.... ?
    Yes they do.
    Attached Thumbnails Attached Thumbnails SD series driver user manual.pdf   servo motors catalogue.pdf
  2. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  3. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
