16-11-2012 #22
The problem is unless it's less than a couple of amps it's hard to regulate the voltage, since linear regulators are extremely inefficient so you can only use them for quite small currents, SMPS's are quite difficult to design and adding more transformers is rather illogical, so I'll be interested to see how you plan to change the voltage. Also if the other appliances only use a small amount of current (making it reasonable to use linear regulators), then the transformers are probably several times bigger than they need to be.
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
WANTED: Power Supply wanted
By fasteddy in forum Items WantedReplies: 6Last Post: 31-07-2011, 11:00 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
