Bearing in mind I'm neither an engineer or machinist but do have a bit of an epoxy fetish ;) I've been going through some designs of gantry and I'm a bit unsure about the feasibility of constructing something.
This is my inspiration and I'm aiming to end up with something similar.
This is the basic gantry concept without any of the supporting struts in place:
It is 60x40x4mm steel box, 1.4m long.
For the struts I can either use solid steel rods or steel angle, the problem I have is that using steel rod will mean welding the struts in place but if I use steel angle I will have to cut and bend the ends of it very precisely to get sufficent surface area for the epoxy joint to hold properly.
Question 1 - is the basic concept a good design of gantry?
Question 2 - is welding the steel rods in place really going to distort the steel, (they will only be small welds, not much more heat than a tack)
Question 3 - Do I have a snowball's chance in hell of bashing bits of angle iron into the right shape using only a few bits of wood and a big hammer?
Any thoughts?
