I can't help thinking that what is needed is not so much a spoon fed full design, but more a decision tree against desired design parameters e.g if you want machine with more than an 1100mm X axis then you need 1610 ballscrews to avoid whipping, if you want to cut aluminium (say up to 6082) then you need to make the frame from extrusions of XxYmm , steel section etc not MDF and so on. Most of the questions I see on here, including my own, are based around trying to make the right decisions and then cost the machine build (time of build is another factor).
The next step is refining the initial build based on feedback (my own benefitted greatly from Jazz, Jonathan, Irving and others), which only comes from being able to leverage real world experiemce on how a machine should perform.
Of course once built there is the added factor of being able to program the thing correctly to avoid broken end mills etc (I'm on that learning curve myself).
If I can find some time I could start the ball rolling, but I have limited knowledge myself, so wiser/more experienced heads than myself would need to fill in the gaps.
Just a thought......
Chris
28-12-2012 #2
I was thinking something similar.
What would also be good is if people that have recently finished their build or are currently designing/building a machine would not only do a build log but an 'after build debrief', so that you can compare the sketchup pics & photos of the machine to an actual rough bill of materials at the end (including tools used) and videos of a few standard cuts to see the real performance.
So for example if we come up with half a dozen test files doing a mayan calender in mdf, plunging into a piece of thick alu, a block of foam, cut out and engrave a piece of acrylic etc. If with have a few videos & photos & speed/time details of different machines doing the exact same jobs it would be much easier for people to form a realistic idea of what they need.
28-12-2012 #3
Nice idea, I'd love a copy of the calendar G code, or is writing it the test (in which case I fail). G.
28-12-2012 #4
The aztec PDF is at the bottom of the first page:
http://www.mycncuk.com/forums/genera...files-dxf.html
The Following User Says Thank You to D.C. For This Useful Post:
28-12-2012 #5
28-12-2012 #6
To save Jazz sending it to everyone, I've just put his copy on my webserver here. If that's a problem I'll remove it straight away. You'll find plenty of other versions on CNCzone. Bit out of date now though
I've not really got anything on-topic to add. I think if anyone hasn't got the small amount of patience required to work out how to make the machine from reading existing build logs, on this site and others, then they're not going to gain much more from a set of plans which are unlikely to meet their specific requirements.
As I've said previously, you can cut aluminium with a screwdriver or knife, so to say a particular CNC router can cut aluminium is not saying much. For me to say a machine 'can cut aluminium', I reckon it would have to be capable of reliably cutting with a 6mm single flute cutter at 1mm per pass. That's nothing special or difficult to achieve, but enough to do odd jobs without getting too bored. The next thing to do is work out what machine stiffness that requires and design to achieve that...
28-12-2012 #7
No problem with me.
I've actually got a version coded for 60Deg cutter if anyone wants it. Don't try using a 60Deg with this code it will come out all wrong and look shite.
With the CNCzone if just downloading G-code be aware it will most likely be for large sizes of 16" or 24" has that was the original sizes. Try to get the DXF if you want different sizes and be prepared to maybe do some touching up.
28-12-2012 #8
Thanks Jazz and Johnathon, I would have to use a 3.175 shank (so 3mm or 3.175) ENGRAVING bit, have various Deg points. I would also like to
have a smaller dia, say 4" or 6", but don't know if I would be able to handle or clean up that amount of code. I would certainly have to drip feed
it, and would certainly like a try. G.
29-12-2012 #9
I agree with what John S has said - this wont get anywhere due to conflicting requirements. One could split the project into designing a set of machines, each aimed at different requirements, but even then people will want something different, or wont be able to source the materials, or tools... etc
The reason I'm most interested in making machines that can cut aluminium is that any machine which is strong enough to cut wood and plastic with respectable speed and accuracy is by default also strong enough to cut aluminium, not efficiently (the milling machine will always win there), but enough to be useful. Unless you make the thing from MDF and do what we might call the classic mistakes, it's hard to make a small machine which isn't capable of cutting aluminium reasonably efficiently.Last edited by Jonathan; 29-12-2012 at 11:27 PM.
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
BUILD LOG: My first project: A fast router...
By Boscoe in forum DIY Router Build LogsReplies: 13Last Post: 14-08-2013, 09:34 AM -
Project CNC Router for all
By Anónio Pinho in forum Open Source Designs & PlansReplies: 0Last Post: 30-06-2012, 01:31 AM -
NEW MEMBER: New to MyCNCuk
By m1ptr in forum New Member IntroductionsReplies: 5Last Post: 28-03-2012, 02:47 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM
