Thread: setting the origin
This is more to do with cutter compensation than the Origin point.? Cutter comp will place the cutter half the cutter dia either to the left or right of the toolpath and often your CAM will deal with this, often it will be called offset.
If your writing code by hand then you'll need to Tell the machine using the G41/42 G-codes which side to apply comp which it then does according to the specified tool IE T1 and the data held for it in the tool table of the control.
The origin is often thought of has just the 0,0,0 or start point of the part being cut. But this really is only the Origin of the WORK coordinate which is located at some point in relation to the Machine coordinate Origin.
Where to place this Work Origin on the bed is totally up to you. The 0,0,0 WORK coordinate is the start point and will never change in relation to the part unless you change it's location in CAD or by writing new G-code.
Where you place it on the bed is entirely upto you and so long has theres enough room for the complete part it doesn't matter because you set the 0,0,0 in WORK coordinates by zeroing the DRO's. The WORK coordinate then has an offset from the MACHINE coordinate Origin which you can not change unless you move the HOME switches. This is how you can get back into position if something goes tits up because the control knows the WORK coordinate 0,0,0 offset point in relation to MACHINE coordinate FIXED Origin.
Micheal mentioned G55/6/7 etc work offsets.? These are just programmable WORK offsets that are a set amount from the MACHINE coordinate origin. These OFFSETS are set in the control. So say your table is 4ft sqr you can effectively divide the table into segments each with it's own 0,0,0 work coordinate.
So say we break it into 4 segments then X0Y0 in MACHINE coords will be first offset, often the Default G54.
X24Y0 will be next offset G55.
X0Y24 will be 3rd offset called G56,
X24Y24 will be 4th G57.
Now Lets say we want to cut a different part in each segment then we would just select G54 for 1st part and the 0,0,0 WORK coordinate starts there at 0,0,0 in MACHINE coords.
Then we select G55 for our next part and the WORK 0,0,0 point shifts to X24Y0 in MACHINE coords and so on for each WORK OFFSET.
So to cut 4 individual parts at the same time each with there own 0,0,0 point we just combine the code in one file with a G54,55,56,57 before the code relating to each part and the control automaticly offsets to that point and uses it has WORK coordinate origin.
Hope this helps and doesn't confuse.??
04-02-2013 #2
No Jazz it makes perfect sense, I tend to set my Origin at the time I'm going to Mill it, mainly because nothing I have done so far is of any identical proportions. The problem was with the cutter compensation was that it began to mill through my clamps ! But I have set it now to compensate for this, however some of my blank wood pieces are not exactly square so it sometimes mills inside the line, but I'm not bothered I'm not making scientific equipment designed to measure things at quantum levels ! I'm making ART lol ! But I was curious to see if its normal, as explained, "it is", and once one knows what is normal one can then change the behavior by specific predictable amounts giving specific predicable results as I have done.
Ralph Waldo Emerson
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
setting up a business
By dstivens in forum Opportunities Available & SoughtReplies: 5Last Post: 16-05-2013, 10:28 PM -
hi i nead help please with setting up dsp control
By cockneyrebel in forum Machine Control SoftwareReplies: 1Last Post: 19-01-2013, 01:18 AM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM -
Need help setting up a CNC router machine please
By 1albobs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-02-2012, 06:16 PM
