Thread: 7' X 4' Combi
@ Jazz..(or Jonathan if you Know) Flat bar say 2" wide ontop of what and fixed how??
I suspect when doing the holes i will get one of those tapping attachments if i go for the single plate.
I can streach to a plate 2000 x 1220 x 10mm at a push for under £600 but will that do the job....
RickLast edited by Ricardoco; 26-02-2013 at 06:03 PM.
26-02-2013 #2
26-02-2013 #3
08-03-2013 #4
08-03-2013 #5
Welding looks good, but the garage looks nearly full!!! G.
08-03-2013 #6Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
08-03-2013 #7
Sounds like an interesting garage set-up. What is the hot-rod? Even with your garage looking so full it is 20x tidier than mine. G.
