07-03-2013 #1
Hey has anybody had any issues trying to upload files to the new Open Source section? i have to be honest that is a section worth having. i think it is a great idea that will go long way to help people out. The problem is file extensions allowed by the site.
Lee if your reading this could you allow
DXF
DWG
CB
NC
NGC
STL
Probably a load more but that is the main ones i use. Might be worth others chipping in here with any more?
Thanks Lee
Great JobIf the nagging gets really bad......Get a bigger shed:naughty:
07-03-2013 #2
If you just change the file extension to .txt then you can upload whatever you want. Not the most secure system is it...
Either way that's mildly annoying, so I expect Lee will do something about it.Last edited by Jonathan; 07-03-2013 at 01:48 AM.
07-03-2013 #3
Agree i know that works but it's much easier if people can see exactly what it is. I'm sure Lee will pick it up.
I think the section is dam good idea though as it gets round the site cnc build problem. At least people can put stuff up and people take what they want without contest between ideas. Surprised you were not the first to put something up?If the nagging gets really bad......Get a bigger shed:naughty:
07-03-2013 #4
07-03-2013 #5
Echo echo? people can read
The problem of nobody agreeing on a forum cnc build. If people are posting their ideas in that section then people can make their own mind up what THEIR forum build will look like.If the nagging gets really bad......Get a bigger shed:naughty:
07-03-2013 #6
Morning guys,
DXF - already present (requested by John S many moons ago)
DWG - added
CB - added
NC - added
NGC - added
STL - added
Its secure JB, the server runs a firewall and also an antivirus, there is also a number of scripts running that keep me informed of server activity ;-).
Yes if people can/would chime in with the file types they work with, its a small task adding support for them so not a problem. I'm thinking there will be quite a few type's so will probably have to do this on a request basis, so anyone reading this please add a request below !
.MeLee
07-03-2013 #7
Added this as a sticky and moved to the Feedback & Suggestions section.
.MeLast edited by Lee Roberts; 07-03-2013 at 11:00 AM.
07-03-2013 #9
Thanks for sorting Lee
07-03-2013 #10
Create dxf file.
By Tanky_Turk in forum CAD & CAM SoftwareReplies: 6Last Post: 10-02-2014, 10:03 PM -
Solidworks file help
By D-man in forum SolidworksReplies: 4Last Post: 19-08-2013, 01:03 AM -
RFQ: CNC brass engraving from an stl file
By Statstastic in forum Projects, Jobs & RequestsReplies: 35Last Post: 04-10-2012, 10:28 PM -
File sharing
By cgw59 in forum General DiscussionReplies: 7Last Post: 02-07-2010, 07:53 AM
