    Agree i know that works but it's much easier if people can see exactly what it is. I'm sure Lee will pick it up.
    I think the section is dam good idea though as it gets round the site cnc build problem. At least people can put stuff up and people take what they want without contest between ideas. Surprised you were not the first to put something up?
    Quote Originally Posted by 2e0poz View Post
    Not sure what you mean by cnc build problem?
    I hadn't noticed it was there! I will be posting things in that section.
    Echo echo? people can read
    The problem of nobody agreeing on a forum cnc build. If people are posting their ideas in that section then people can make their own mind up what THEIR forum build will look like.
    Lee if your reading this could you allow
    DXF
    DWG
    CB
    NC
    NGC
    STL
    Probably a load more but that is the main ones i use. Might be worth others chipping in here with any more?
    Morning guys,
    DXF - already present (requested by John S many moons ago)
    DWG - added
    CB - added
    NC - added
    NGC - added
    STL - added
    If you just change the file extension to .txt then you can upload whatever you want. Not the most secure system is it...
    Either way that's mildly annoying, so I expect Lee will do something about it.
    Its secure JB, the server runs a firewall and also an antivirus, there is also a number of scripts running that keep me informed of server activity ;-).
    Yes if people can/would chime in with the file types they work with, its a small task adding support for them so not a problem. I'm thinking there will be quite a few type's so will probably have to do this on a request basis, so anyone reading this please add a request below !
    .Me
    Added this as a sticky and moved to the Feedback & Suggestions section.
    .Me
    I tried to upload a spreadsheet yesterday and it wouldn't accept .xls
    Thanks for sorting Lee
  1. Create dxf file.
    By Tanky_Turk in forum CAD & CAM Software
    Last Post: 10-02-2014, 10:03 PM
  2. Solidworks file help
    By D-man in forum Solidworks
    Last Post: 19-08-2013, 01:03 AM
  3. RFQ: CNC brass engraving from an stl file
    By Statstastic in forum Projects, Jobs & Requests
    Last Post: 04-10-2012, 10:28 PM
  4. File sharing
    By cgw59 in forum General Discussion
    Last Post: 02-07-2010, 07:53 AM
