Thread: F-Engrave problems
hi
The install was easy. I can import a picture. v_carve calc. can run, but When I want to save the G-Code, this following error up in the black window:
"Unicode encode error: ASCII codec cant encode character u '/ xe9 in position 56: ordinal not in range (128)"
Please somebody help resolving this problem!
16-03-2013 #2
In text mode F-Engrave does not support characters with a value greater than 128. (These extended characters greater than 128 are my list of things to add support for someday.) The error Szasza880210 is reporting is occurring in "Image Mode". I will look into fixing the error that is occurring in "Image Mode".
Until I get a new version with a fix for this error you may be able to work around this problem by switching to "Text Mode" and deleting all of the text in the "Input Text" box, then return to "Image Mode" and save the g-code.
EDIT: I looked into this a little more... F-Engrave should support characters up to 255 in the latest version. Make sure you are using the latest version (V1.02) from:
http://home.comcast.net/~sskroch/Fengrave/fengrave.html
Feedback on whether the fix works or not will help me with correcting the program.
ScorchLast edited by Scorch; 16-03-2013 at 04:54 AM.
16-03-2013 #3
HI
YEs i use a (1.02) version.
Yeah sorry I did not write it, the problem is in image mode. Thanks for the advice but failed again, the error message is the same. Simpler images, all right, but not the more detailed images. Thank you for help, for now I use Simpler images. And i wait for a fix or a new version of the program.
17-03-2013 #4
@ Szasza880210
Right now I am not sure what is causing the error. I have not been able to replicate the problem. If you are willing you could send a sample image file that exhibits the problem so I could try to replicate the problem. (The best way to send an image is via e-mail to the e-mail address in the F-Engrave help menu.)
Scorch
18-03-2013 #5
I think I have found the cause of the error. If the input image file name contains a non ASCII character (i.e. A character with a decimal value greater than 128) F-Engrave will throw the reported error:
As a work around the input image file can be renamed to something with only ASCII (English alphabet) characters before importing the image into F-Engrave.
I will include a fix for this problem in the next version of F-Engrave.
Scorch
24-06-2013 #6
Could I ask a quick question scorch
I have installed your program on my office machine ( win7) no problems so far
when i come to install it on my workshop machine( win xp sp3) i can't get it run after installing
The dialogue goes " the application failed to start because the application configuration is incorrect reinstalling may help""
Any ideas?
as an aside if I try and install on a laptop (win vista) it works fine
But I do need teh program on my workshop machine
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
