Thread: Upgrade? Chinese CNC Machine
02-04-2013 #12
Hi there, try and slow things down a bit 200 steps per and velocity 200 accel 100 and see if you get different results, also what are you using to Generate your G-Code. Also have you run the driver test for mach to see if it is running as should be. Is the machine dedicated to CNC or are you running other stuff in the background..
RickLast edited by Ricardoco; 02-04-2013 at 02:37 AM.
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
