hi,
just noticed this thread, what material and quantities and timescale are you looking at?
might be able to make some of the bits in the evenings after work if that helps you out
11-08-2013 #2
For all the drawings posted, unless stated, the material is aluminium, some machineable grade such as 6061 but depends on what can be picked up on eBay/etc. As to quantity, 2 off each drawing (i.e 2 cranks, and 2 handle assemblies comprising 5 parts, handle/boss/axle/2xspacer). Timescale, well I need to get exercising, so ideally as soon as possible, maybe within 4 weeks?
11-08-2013 #3
ok not a problem should be less then 3 weeks, got some 6082 bar ends at work that can use if 6082 is ok?
will need some extra dimensions on the boss as cannot open the .dxf files
hope this helps
11-08-2013 #4
Just seen this I can help if needed. . . . . just let me know. Got some stuff here if needed
PS: Can do them Wed if that helps.!Last edited by JAZZCNC; 11-08-2013 at 10:51 PM.
Second hand machines & their features
By navins in forum Machine DiscussionReplies: 5Last Post: 19-03-2014, 11:01 AM -
Hand Ergometer
By irving2008 in forum General DiscussionReplies: 50Last Post: 11-08-2013, 05:55 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
