I just noticed Jazz's point about slaved motors.
My upcoming build does not use slaved motors, but that's not to say i won't in future.
The CSMIO has an in built facility to slave motors independently of Mach. This however is NOT available in the M version.
You can however still slave motors via Mach with the CMSIO "thinking" two slaved motors are independent axes, but CSMIO-M is limited to 4 Axes so that's something anyone reading this and considering buying the CSMIO-M should be aware of.
WARNING:
Slaving within Mach could be a very bad idea when using the CSMIO-M
Please check posts below for updates, or better still check with CS-labs before making any buying decisions
GreenyLast edited by Greeny; 06-09-2013 at 01:54 AM.
06-09-2013 #2
This needs checking carefully thou because every other motion control card I have used takes the duty's of homing away from Mach3, it's a technical issue I think and comes has part of the deal of external motion control.?
So while CMSIO may allow slaved independent axis that doesn't mean it will treat them combined while homing then independent for squaring which is what you need for slaved axis when homing.??. . . . .Best check with Manufacturer first.!!Last edited by JAZZCNC; 06-09-2013 at 12:34 AM.
06-09-2013 #3
Ahh, I did not realise that.
So potentially, slaving a motor in Mach when using a CSMIO could be a very unwise thing to do.
Apologies for bad info. Note to self. Check facts before offering dodgy info!!!
I have edited my post to warn and will check with CS-Lab about this
Greeny
06-09-2013 #4
Give another point to ESS,
They really do help if their are issues and once fully set up it runs a dream. When tuning my motors I can get a solid .005 to .01 mm repeats (the DTI and Plunge gauge are calibrated to +/- .01) which literally puts the machine up against the ability for me to accurately measure. That is with C7 screws Zap NEMA23 "24" 3.1 NM motors. Running Mach 3. B.O.B is a PMDX-126 and the power supply is a home built toroidal transformer providing ~68V w/ 15A. It does the job. Have the spindle on the relay on board the PMDX and also a secondary relay off the PMDX so that power is cut during E-Stop.
With Geckos and the Jumbo mode on a PMDX 126 or the ribbon cables you can set up a rather power system if you have the time effort and funds.
-MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
06-09-2013 #5
Any recommended retailers for the ESS or are you guys buying direct?
06-09-2013 #6
Peter Homann is a Good guy to deal with and knows the SS very well and helpful if you have any issue. (He's in Oz.!! thou not a problem.)
SmoothStepper Controllers : Homann Designs!, The preferred CNC Component Supplier
I've also bought direct from Warp9 and while they deliver ok getting any help from them quickly can be hard at times, peter is much quicker to respond and knows is stuff.! Last time I bought there was Hardly any price difference due to currency at time.!!
10-11-2013 #7
I've recently ordered a PDMX-126 and a Smoothstepper ESS to use with my machine which will be running twin screws with slaved steppers on the long axis (1200mm long). I've just been reading that there is an issue with the SS regarding homing slaved motors using two switches (one per motor) : Ethernet Smooth Stepper, What Are The Negatives, What Features Are Missing?
Does anyone have experience of this? Is there a workaround apart from only using one switch?
Cheers,
Si.
USB TO Parallel Port DIY Interface
By Lee Roberts in forum Electronic Project BuildingReplies: 42Last Post: 17-02-2018, 07:46 PM -
What is the function of a parallel port breakout board?
By hbx in forum Machine Control SoftwareReplies: 13Last Post: 12-03-2013, 06:18 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Laptop, ie no parallel port?
By tompsky in forum Laptops & TabletsReplies: 3Last Post: 11-11-2008, 07:12 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
