  1. #8
    Quote Originally Posted by Greeny View Post
    I just noticed Jazz's point about slaved motors.
    My upcoming build does not use slaved motors, but that's not to say i won't in future.
    The CSMIO has an in built facility to slave motors independently of Mach. This however is NOT available in the M version.
    You can however still slave motors via Mach with the CMSIO "thinking" two slaved motors are independent axes, but CSMIO-M is limited to 4 Axes so that's something anyone reading this and considering buying the CSMIO-M should be aware of.
    Greeny
    This needs checking carefully thou because every other motion control card I have used takes the duty's of homing away from Mach3, it's a technical issue I think and comes has part of the deal of external motion control.?
    So while CMSIO may allow slaved independent axis that doesn't mean it will treat them combined while homing then independent for squaring which is what you need for slaved axis when homing.??. . . . .Best check with Manufacturer first.!!
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 07:46 PM
  2. What is the function of a parallel port breakout board?
    By hbx in forum Machine Control Software
    Last Post: 12-03-2013, 06:18 PM
  3. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
  4. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
  5. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 03:38 PM
