Thread: A sufficiently strong machine
26-10-2013 #20
A couple of questions as i am designing my own build, using your ideas:
-so you believe 3kw spindle would be better than 2.2kw?
-how you did the oiling system? did you use the original nipples and modify them? why not grease? how much oil is used under operational condition? What oil?
-where did you get that spring shims that make the preload? what are the specifications? how did you calculate the distance between the 2 nuts , so that they would be mirroring each other exactly and the shims to fit in?
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Strong 1212ds - any advice greatly appreciated!
By MrWiz73 in forum General DiscussionReplies: 14Last Post: 30-03-2011, 05:17 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM
