Thread: New CNC Mill on the horizon
I've got round it in the past by ordering ballscrews and rails at the same time, since the rails add sufficient strength to the package, but if you're getting the rails elsewhere that's not much use.
How long are the bent ballscrews? You can try clamping it between V-blocks, and pushing down in the middle to bend it back... but it's not going to be easy.
04-11-2013 #2
04-11-2013 #3
My stuff arrived today has well, wonder if they came on same shipment.? Don't know if dare say this but my stuff is ok but I did have other stuff which supported the screws plus they where only 1300mm long.
Depending how bent then like Jon says V bollock and plenty of force, I've straightened screws before but it's slow process and easy to over do and bend more.
If not too bad then I'd fit on machine and see how they perform, sometimes they can be ok when running and not affect machine too much.?? . . .they can also shake the bastard to bits but worth a try.!!
04-11-2013 #4
05-11-2013 #5
My ball screws from Chai were wrapped in plastic, encased in foam and wrapped in a cardboard square tube/box which was liberally wrapped in yellow tape. Not checked mine yet to see if they're straight....might be doing that sooner rather than later now!!
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
