Is my BOB too close to the mains, I wonder? Having said that, I ONLY get resonating within a fairly tight range of low end speeds. What problems are usually caused by not screening cables? My panel is just straight tri-rated panel wires. I've tried to keep the mains and signal cables apart as much as is practicable. Cables connect to the motors via metal cored industrial 20mm Adaptaflex.
18-11-2013 #2
I don't think your BOB is too close to the mains, I used CAT5 4core (2 x twisted pair) networking cable for the connections between the BOB and Stepper Drivers as this eliminates a lot of interference.
The problem you describe does not sound like a wiring problem and is likely to be resonance. I noticed the gap between the motor bracket and the machine was very small in places and I wondered if they were vibrating against each other like a tuning fork ?Last edited by EddyCurrent; 18-11-2013 at 11:34 PM.
18-11-2013 #3
I didn't think it was a wiring issue either, but wasn't sure if the steppers and drives are prone to doing weird things with mains cables in the vicinity, etc. Yes, the clearance are a bit tight in places but the motor is still resonating when I take it off the mounting and sit it on a rolled up rag. The noise is obviously less but the vibration can be clearly felt at certain low speeds.
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
motor mount vibration vs torque'd bolts
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 22-10-2013, 10:36 AM -
M542 driver (Zapp) half or full current?
By Smiler in forum Stepper & Servo MotorsReplies: 9Last Post: 09-07-2013, 09:02 PM -
M542 Driver
By Swarfing in forum Motor Drivers & ControllersReplies: 28Last Post: 28-06-2012, 09:12 PM -
ZP5A-INT breakout an M542 driver problems
By ciaranconlon in forum Motor Drivers & ControllersReplies: 2Last Post: 09-04-2012, 05:52 PM
