Exactly what I feared!! I will do some more thinking, need to research rotating nuts first as I'm not at all familiar with these, then I can hopefully come up with something. The covers are pretty resilient though and will stop most foreign bodies, with those plus regular cleaning I think it may be the best option as it gives the most strength.
I'll give it some thought! Any other glaringly obvious mistakes in the design??
10-01-2014 #2
Not glaring but you have gone too far with removing the diagnols but not far enough in other places.?
I would have diagnols at each end of the sides. But would remove the central upright and re-space others on all the Bed support frames.
Would also have a Bed support frame on each side upright and not laid flat in like you have in centre.
The rest looks ok.
EDIT: I would also on the outer End bed supports have diagnols on inside lower beam which fastens to the sides to help hold frame square while setting up and bed frame is fastened. Like this but larger and to suit your design.
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
