    Are you going to make a moat between the two rails so that they will be both at the same level, also the epoxy will rise up at the edges so make sure you have a wide enough flat plane to mount the rails on say at least 10mm each side. ..Clive
    Clive, would you say it was easier to drill and tap all the holes for the rails after doing the epoxy?
    Neil...
    Build log...here
    I take it that you have seen the pics that I posted. When the mdf sides were taken away you will find that the epoxy has crept up the sides a little. I then used a flat file to scrape the high sides away just until you see it marking the centre. I left mine to cure for about 3 days before removing the mdf. I just drilled through the epoxy and steel and then threaded in the normal way. It was way easier than I had thought.
    When mixing the epoxy I did it by weight, I was told by the very helpful people at Wests to mix it in a wide container as that would produce the least heat. There is no problem with mixing it in one or two batches, I also used a hot air gun to flash the surface after it was poured to get rid of any bubbles in the surface. I believe that the proportions of the two part mix should be done accurately . Hope all this helps biggest tip is sealing the moat for leaks before you start as that will give you problems. ..Clive
  1. traveling steady, turning 1/2 bar down over 10".
    By graffian in forum Metalwork Discussion
    Last Post: 08-05-2013, 07:59 PM
  2. NEW MEMBER: Hello all, finally ready to start a build log.
