Thread: Build and Intro
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. #31
    EDDY I can confirm that the switches work as they should when there is no power going to the stepper motors. I'm guessing I have to now re wire switching wire with shield wire of some kind??
    thanks
  2. #32
    Man its been a while since I've been on here. Time for some pics!
    Overall I'm pretty happy with how the machine runs, especially seeing as I made it with zero plans/planning, a big no no on here haha. Haven't had any major problems and once I received the new driver everythings been sweet. Still haven't wired up any limit switches, I'm lazy.
    Some videos
    DIY CNC Router Flush Handle - YouTube
    DIY CNC router pocket - YouTube
    Here's a few things I've been making....
ID:	11462   Click image for larger version.
ID:	11463   Click image for larger version.
ID:	11464   Click image for larger version.
ID:	11465   Click image for larger version.
ID:	11466   Click image for larger version.
ID:	11467   Click image for larger version.
  3. #33
    Those doors are great, what cutter did you use for that ?
  4. #34
    I used a 85 degree 2 flute v cutter. The holes are all the same distance apart centre to centre however there size changes according to depth(deeper equals larger). I'll put up a link to the free program when I'm on a computer.
  5. The Following User Says Thank You to swisscheese For This Useful Post:
  6. #35
    Great stuff. G.
  7. #36
    Quote Originally Posted by swisscheese View Post
    Any chance you can post that link ? thanks in advance.
  8. #37
    My guess would be the software by this guy...?
    http://jasondorie.com/page_cnc.html
    In fact, seeing a link to his software was one of the first things that got me into cnc machines!
    Nice job swisscheese, looks really good!
  9. The Following User Says Thank You to cncJim For This Useful Post:
  10. #38
    Quote Originally Posted by cncJim View Post
    CNC Software
    Yes that's the link.
    Might take you a few shots to get it working well.
    A few tips
    Make centre distance between holes about 0.4mm bigger or more than hole size.
    Set z retract limit quite low, I do mine at 2mm
    High contrast images work best
    Also look up iannonne design. He has some great furniture with nice disigns on it using this and other techniques.
  11. The Following User Says Thank You to swisscheese For This Useful Post:
  12. #39
    Good tips, thanks. I haven't tried using the software yet as I think my machine might die from all the z action! First thing I will try when I upgrade though.
    What sort of times did your half-toning take to machine?
    Jim
  13. #40
    Jim
    Also another
    Start with min hole size at 1 mm and max around 4.
    Melamine faced chip board and laminated mdf work good.
    I have never timed but I would estimate that one of those doors ( from the tree cabinet) took around 1 to 1 and a half hours. Those doors were 15 thousand holes each. Probably could go faster but as you say you don't want the z axis losing steps as it works very hard and would be a bugger to reset.
  1. NEW MEMBER: Intro
    By vt356b in forum New Member Introductions
    Last Post: 02-09-2013, 11:39 AM
  2. NEW MEMBER: New here - new intro
    By ChrisTerry in forum New Member Introductions
    Last Post: 05-08-2012, 11:09 AM
  3. NEW MEMBER: Intro
    By Ian Hart in forum New Member Introductions
    Last Post: 22-02-2010, 06:06 AM
  4. NEW MEMBER: Hello / Intro etc
    By pjm in forum New Member Introductions
    Last Post: 23-01-2010, 05:59 PM
  5. NEW MEMBER: Intro...
    By Davidh in forum New Member Introductions
    Last Post: 29-08-2007, 01:58 PM
