Thread: Rob's Build?
Ah I don't think Zapp do the kit I bought anymore and the closest to mine is the High Voltage 3 Axis one here: High Voltage Digital Driver Kit (Four axis)
The description has an error as this is actually the 3 Axis kit using DM856 drivers (mine was an earlier analogue version using AM752 drivers).
If you are going to cut wood only (I cut a lot of aluminium) then you maybe able to use the lower voltage kit - others will be able to advise.
As Jazz says though - the electronics is something further down the track - get the frame, gantry, ballscrews, rails, bearings etc. sorted out first.
14-03-2014 #2
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
