I'm interested in any ideas as to the test request above ?
I know electronics
I don't know the voltages involved with laser PSU's .. Will (google in a bit)
I almost seems as though they want me to wire up a thin piece of wood and see if I get an "Ignition Phenomenon"
I have a multi meter (1000v)... and lots of different value resistors .. could I rig up a quick test circuit to test if the laser PSU has an output ?
02-07-2014 #2
Have a look at this:- https://www.youtube.com/watch?v=Qz6J4Rs7VCw The voltage you are playing with is about 10Kv 10,000V So yes they are asking you to put a piece of wood in to see if it burns up
ah !
It seems they sent me a wrong link to a video .. it just showed the machine cutting a smiley face !
After some google translate'ing and searching I found this ...
http://v.qq.com/boke/page/t/0/9/t013170ath9.html
(You have to watch the ad' 1st)
I shall test and let them know the result :)Last edited by Want2build1; 03-07-2014 at 01:31 PM.
03-07-2014 #4
I thought they wanted you to use a piece of wood to push the wires together to short them and see if they spark. It's an amazing spark and pretty loud but not something I would do voluntarily.
I would examine other parts of the system first such as the enable laser button to make sure its working and the connections are solid.
03-07-2014 #5
ok , just finishing for tonight. rigged up the test as in the vid .. nothing
Does the test button on the PSU bypass all the safety features, like the water pump ?
I'll double check all the wiring in the morning, and try again
03-07-2014 #6
No, test button needs the other safety features to work :)
03-07-2014 #7
Laser Machine Grounding/Earthing
By Want2build1 in forum Laser Machines & BuildingReplies: 31Last Post: 09-02-2015, 10:18 PM -
50W CO2 Laser Machine Unboxing, Review, Modifications & More
By Want2build1 in forum Laser Machines & BuildingReplies: 52Last Post: 01-02-2015, 06:18 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
How to save laser machine cost
By Zoe Zhang in forum Manufacturer NewsReplies: 0Last Post: 06-09-2012, 03:41 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
