Thread: Giant 20' x 3' x 2' router build
14-11-2014 #26
If machine is moving and you hit STOP then you really should presume the machine as lost position and Re-home. If you want to pause the machine and resume then you should use FEEDHOLD.
If machined is STOPPED and you want to resume from point in the G-code then use the RUN from HERE command. This will do a move back into position then pause with message asking for CYCLE START it will also give you option to start the spindle.
If using RUN from HERE then it's best done from the begining of Cycle or some position move in the code rather than half way thru canned drill cycle for instance.
RUN form HERE as saved my arse so many times I've lost count and use it all the time.Last edited by JAZZCNC; 14-11-2014 at 03:36 PM.
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
