    It is very possible to go on with epoxy finally as I measure gap (beam against straight edge ) nearly 0,25mm and shimming seams to be very difficult for me.
    As i had told here in Greece they import 105 west system epoxy but they don’t import 209 hardener but only 206. So i will make some experiment with other epoxies much more cheaper ( 25 euros / 1,2 kgr). Ebay supplier asks 90pounds for 1.2 kgr 105-209 system.
    The problem is that the temperature in my work place is now 16-17 celsious and it is dropping more as Decemper comes. So if i want to apply the epoxy method i will have to make a place with controlled heating system in order to keep the temperature as low as 20-21 celsious.
    Second solution will be to go on with shimming and third ( the most expensive ) to ask a friend of mine ( that builds woodcutting machines) to use one of his machines and mill my top beams in order to come in the same plane ( but this will cost).
    I want to ask
    #1 ( very important to know what I am trying for )
    When you measure the flatness of a beam ( or epoxy surface) against a straight edge, what is the acceptable tolerance-gap ( so we assume the surface is straight) . I use light to understand whether my top beams attach the straight edge. The touching points can be easily seen. But at other points althought i can see that there is no touch ( light passes through) , the 0,02mm Gap Filler cant pass through the gap. So what is the critical gap ? the light passing test ( that is less than 0,02mm ) or the 0,02mm gap filler test?
    #2
    When someone use the solution with the adjustable top beams ( without epoxy) or the shimming method how does he succeed to have the top rails in the same plane. How does he know when the two rails ( left and right ) are in the same plane? Is the thread method accurate ( the method that with the use of two threads you create the diagonals of the top rails like X. If the diagonals are in touch at the centre that means that the rails are in the same plane.
    #3
    When we use the epoxy method we first drill then tap then close the holes and then apply epoxy or we apply epoxy then drill and tap?
    #3
    What is the right angle to hold a single beveled straight edge? 90 degrees?45? something else?
    Thanks for your time
    Vagelis
    The creative adult, is the child who survived
    Quote Originally Posted by ba99297 View Post
    1. I read the hiwin maual and it says ( for carriages lubrcation ) to use lithium soap base grease. Is tha a MUST or i could use oil ( and what oil ) instead of grease.
    2. Do we also lubricate the rails or only the carriages?
    1. I think if you use grease then the lithium is a must, but oil can be used, Jonathan used it here for example; http://www.mycncuk.com/threads/6484-...strong-machine
    I get the correct grease here; http://www.toolstation.com/shop/Auto...se+400g/p89691
    2. Lubricate the carriages only, they will pass lubrication onto the rails.
    #3
    #4
    3. I drilled and tapped all the holes after I poured the epoxy, there were no problems by doing this.
    4. 90 degrees because you do not want the straight edge to bend in the middle.
    I've been working on my machine this evening, and I think that we are a very similar stage of build! I was levelling the frame of my machine (similar size - cutting area about 1500x750) and thinking about epoxy. I have already bought my epoxy (Reactive Resins low-viscosity with slow hardener) but they say that it should not be used below 8C. In my part of the UK at the moment, that's about the night-time temperature and daytime is only about 12C (and probably slightly cooler in my garage).
    As well as I can measure it, I have a dip in my rails of about 1.3mm in the centre. Not as accurate as I would like - not sure if it was a bend in the original 100x50 box sections, or welding distortion - but I think that that will be fine with epoxy. However, I could shim it, if I can find some suitable material. Epoxy has the advantage of also bringing both rails into the same plane, of course, which would be much more difficult with shims (tapered shims, anyone?). What I don't know is what kind of tolerance you need to work to with Hiwin rails - what kind of relative twist in the two rails is OK? If both rails are perfectly horizontal in both planes but one is, say, 1mm higher than the other, would this matter? On my machine, that is a twist in the bearing block of about 0.06deg, or 0.001mm across the rail. Doesn't sound like a lot to me, but I have no practical experience of the real-world tolerances on these things.
    I'm planning to epoxy first and drill/tap through the epoxy and rail later. My feeling is that this will be easier, and certainly better than trying to remove the epoxy that has leaked into the tapped holes.
    I have done the first machine at 14-16C, but i believe any lower is not good idea.
    For 20 size z1 preload :
    -mounting surface parallelism 0.02mm
    -block mounting surface 0.01mm
    It will withstand more, just loosing life expectancy.
    any CNC producer can be happy with this. I am just wonder how did you measured this 0,001 mm?
    Something came to my mind. When doing the epoxy thing, they both should be one temperature with the frame. Means Not pour and then turn the heater on as it would be a disaster. bring a heater to the workshop, turn it on for a couple of hours so the epoxy and the frame will be one temperature. Then leave it for overnight while the epoxy is cured.
    regarding to the epoxy itself it seems good thing against vibration too .
    Pls advise about the strength and hardness with comparing to ie. AL.
    When one bolts onto a rail with M6-is its compression negligible?
    Quote Originally Posted by vargai View Post
    I didn't measure this directly. It's based on a difference in heights of rail of 1mm and a rail spacing of 1m. Looking at the hiwin catalogue, I think they say that the bearing blocks can tolerate a slight rotation around the rail, and a height difference of 0.26mm (20mm rail, 1m spacing). This is a lot more than the figure that Silyavski has given, but I might have misunderstood something.
    Only the 1 micron (you wrote 0.001mm) seemed to tight. The angle is correct, the level deviation on 20 mm is 0,02 as my dwg says
    It is one magnitude bigger but I do not think it has too big impact on a router-by the way I would not be satisfied either with 1 mm on 1 m because deviations accumulates according to the Murphy catalogue
Name:	1mm on 1 m.JPG
    Perfectly correct, Vargai - I forgot to multiply the "1 in a 1000" ratio by the width of the rail. I've slapped my own wrist...
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
