Thread: Accurate Strong Gantry
The general opinion is that if >70kg you can not move it adequately with 2x3nm motors so you need bigger motors, which now puts you into position to find bigger but at the same time fast enough or go with servo, which to me seemed the better option.
Now i am looking back at your gantry design. What size are the profiles, why 4, why are not connected each other? Whats your idea there? At that size machine
2x 100x100x3 or 100x100x4 welded together with separation for ball screw or not /if back/ will be ideal. 100x100x3 weights ~9kg/m and the 4mm weights 12kg/m, So you co8uld still move that gantry by 2x3Nm nema 23
03-12-2014 #2
The modification is being processed hopefully more optimal now but from steel I have no to big margin with Z+Y plate gantry legs and all stuff (some item was hided on my dwg ) so it will be 100 kg anyway
When I saw my friend machine with the moving bed I said I would not want to move to and fro 120-150kg mass with material so it would be moving gantry.
Entering to this 700x1000 mm machining zone with rigid steel design I have to revise myself.
I am seriously thinking of the moving bed option now it is just 5-700 mm longer space and can forget many trouble i.e the dual motor, heavier spindle
My goal is a bit better an more accurate machine than a router so called semi industrial so within a 4000 -4500 GBP budget I would like to reach the best performance.Last edited by vargai; 03-12-2014 at 08:04 AM.
03-12-2014 #3
If you have the space then Fixed Gantry is the way to go without any doubt but the principle still applies regards motors and moving mass. There is nothing wrong with regular steppers if sized correctly and if used with quality Digital drives and external motion control card, which you would 100% require for servo's, then they won't lose position and will hold high accurecy without any encoders.
Regards Hybrid easy Servo's then I'm sat on the fence because while I know they work excellent I agree they are too expensive and Servo's can be bought for not much more money.! . . . BUT . . .And for some it's a very Big BUT.!! Servo's require more knowledge of setting up to get the best from them and can be nightmare to tune correctly, espicially if other electronics are not done correctly and noise is introduced has they are much less tolerant of noise in the system. (It's not uncommon for some one to turn on a dodgy radio or some noisey appliance and Servos take off at full speed.
I have seen people, experienced people, build machines or retro fit Mills with servo's only to change them at a later date with steppers because they can't get them running correctly or reliably. . . . Reliably being the key word.!! . . . . Now I'm not saying don't use servo's but I just mean be aware that they are not simple and can turnout to be more trouble than there worth for the inexperienced.
Hybrid easy servo's don't have this issue as they are essentially steppers with encoders for checking/correcting position.
Regards the machine I Try to always keep in mind the three most important goals of a CNC machine which in my opinion is accuracy, repeatabilty and finish quality.
Accuracy and repeatabilty comes from component quality and suitabilty along with machine ridgidity and attention to build.
Finish quality comes from some of the above but mostly from Ridgidity and machine design and while all three are important aspects the quality of finish is what I'm always aiming to improve. Achieving the best best finish quality is mostly about lessening tool deflection and chip clearence.
So if you can keep the tool stickout distance from spindle to a minimum and have the shortest Z axis extension you'll get the best possible result and it's here I'd look to improve machine design and in my opinion you won't go wrong if you follow this design. (which I'm sure he stole from my Head.
) Just make a better, stronger Job and put proper spindle on it.
03-12-2014 #4
03-12-2014 #5
07-12-2014 #6
I will go on with the Fix gantry system because it is properly fit to my goal -the moving bridge is a big advantage and present for me- so I am not restricted with a fix bridge height.
However I do not want to cut this line and leave it this way.-probably I will make gantry with this principle too.
Some draft are attached with the gantry base solution.
I prefer to save the expensive, vulnerable parts
balls crew rail , belt drive so I tried to hide them next, behind or under the frame -I belive this is the best place for them against the impact of
-work piece uploading
-chips
-coolant
The other view is to apply the roof trusses principle where incredible small profile in a certain arrangement can form a very strong element.
In my dwg the three SQtube run along he perimeter tying to each other with reinforcement plates.
It is a pity I cannot check and compare the different version with software so only suppose it gives big torsion resistance to the frame
07-12-2014 #7
Looks good but you might need a bit more triangulation. The thin gussets only work in one direction so ideally you need them in equal amounts in all 3 planes.
Why is there a bit gap in the middle?
What rails are you using? There are different types and some can handle 4 way loading and others cant so are best mounted on top of the rail. Espesially if you are using a heavy moving gantry.
07-12-2014 #8
07-12-2014 #9
The base frame version just idea for future project where the purpose and load let me use this principle.
Yes this is weak point of this design to achieve the straightness and parallelism
- correct more expensive method to machine it - can be done in one step w/o flipping the frame on the machine bed (drilling by DIY)
- DIY method
-I am sure you will invent it
By the way I am wonder about the cost of the
epoxy system comparing to the machining.
If you have access to earn money in mean time with other job I think machining cost can compete with DIY cost Sum.Last edited by vargai; 07-12-2014 at 03:23 PM.
07-12-2014 #10
Yes some corrective action should be done .
The gap in the middle just represents the place of the single ball screw in case of narrower machine
regarding the rail I would use one like this which is regular type now
The problem is as you pointed to it at my case only the upper row of ball hold the load but the moment resistance is good that occurs at start-stop and direction change
I have no experience using it but suppose it works -the catalogue also mention it as possible mounting arrangement
Because of my 100kg+ heavy moving gantry I have drooped this design and go with fix gantry where the moving Z will be balancedLast edited by vargai; 07-12-2014 at 04:25 PM.
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
Just kidding.
