Thread: Boxford 160TCL to Mach3
you can get a good working machine for very little expense by using the existing drives, power supply and steppers. You can get this within the constraints of a single parallel port even with the atc if fitted. The existing power supply and drivers will run the steppers well, but if you need more performance, more powerful drivers and a larger power supply will be needed. What you need to decide is what you want from the 160 and even if you need greater performance.
13-01-2015 #2
13-01-2015 #3
The Mach3 license is very reasonably priced (especially with the current exchange rate) at $175, then as stated you can add a break out board (BOB) and PC running W98 with parallel port and you just have some wiring to do ;-)
- Nick
13-01-2015 #4
08-02-2015 #5
Hi all
I have just aquired a boxford 160 and 190vmc and i am looking to convert them to mach3. i also have very little idea of how to go about it. i have been looking through the threads on here and i am getting an idea of what it entails but i am looking for some help
cheers
21-10-2015 #6
Morning,
I've also just bought a TCL160. Mine looks like a bog basic model, no tool changer turret or limit switches on axis. Everything it has works though, quite happily moves in jog etc.
Is it possible to get it running on a PC in completely stock condition? If I could do that and keep the use of the control panel I'd be very pleased. If not, are there any idiot level guides to putting new boards etc? I've seen Saracens thread, though it sounds like he's still experimenting and setting up. I've downloaded the free version of Mach 3 to have a look.
Boxford vmc260 to mach3 conversion
By jamesgates1000 in forum Boxford Vertical MillsReplies: 22Last Post: 30-01-2020, 11:47 PM -
CONVERSION: boxford vmc 300 mach3 conversion
By bigred5765 in forum Conversion Build LogsReplies: 14Last Post: 05-07-2018, 06:05 PM -
Boxford VMC 190 to Mach3 questions
By swood1 in forum Boxford Vertical MillsReplies: 3Last Post: 08-08-2014, 09:40 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM
