    Im looking for the right kind of cable to extend my nema 23 steppers, 3amp cable, also a cheap version of lead screws? any links would be appriciated
    Quote Originally Posted by universally View Post
    A lot of people on here use 4 core CY cable 1mm or 1.5mm. What type of lead screw are you looking for? ..Clive
    please delete post.
    You will want to buy FLEX CABLE, SHIELDED, 18AWG, 4CORE /0.8mm/
    ALPHA WIRE,2424C SL005 is the cable i use. Yeah, its better than the Chinese one the others sell for almost the same money.
    hi guys thanks for the cable info :) and clive im currently using threaded bar just for the build and to check motion etc but i do want to use something more accurate and robust but the price tags are way out of my league from what i have seen, was maybe considering chain drive?, my bed size is 1200x1000mm
    And what's wrong with CY cable and who are the others? ..Clive
    I dont like CY cable for stepper motors. I like it for the spindle to VFD. The others are = "ebay search stepper cable" . What i say is that better buy brand cable for steppers.
    Brand cable like http://www.control-cables.co.uk/cy-cable/ there are lots of "branded" cable please inform me and others why you don't like CY cable and why it is ok for spindle and not for stepper motors. ..Clive
    OK,
    For spindle i buy SY cable. Sorry for the mistake.
    CY cable is not true "flex" cable . Nothing wrong with it.
    Minimum bending radius for:flexing:
    20 x cable outer diameterstatic:
    6 x cable outer diameter
    Temperature range:
    flexing: -5°C up to +70 °Cstatic: -40 °C up to +70°C
    I like "flex cable" . Flexy, you know. Easy to bend , thin for the size, easy to solder.
    OPERATING TEMPERATURE:
    ■ –20°C to 60°C
    But you Clive, feel free to buy and to recommend whatever cable you like. I just stated my recommendation. Its personal preference. Nothing more.
ID:	14425   Click image for larger version.
ID:	14426   Click image for larger version.
    Well from the link I posted "CY cables come with a grey sheath, are highly flexible multi core cables with (class 5) copper conductors. They also have a voltage rating of 300/500v, having been manufactured to meet the requirements of BS6500 and VDE0250." it seems they are flexi.
    Anyway we will have to agree to disagree. ..Clive
  1. Replies: 4
    Last Post: 02-01-2015, 08:32 AM
  2. First couple of parts...
    By Wal in forum Metalwork Project Showcase
    Last Post: 14-02-2014, 03:41 PM
  3. RFQ: Looking to get a couple gears modded
    By m_c in forum Projects, Jobs & Requests
    Last Post: 23-11-2013, 09:34 PM
  4. NEW MEMBER: Spanish newbie (with a couple of CNC projects for photography)
    By ECardenal in forum New Member Introductions
    Last Post: 09-08-2011, 11:17 PM
  5. NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
    By m0nk3hjam in forum New Member Introductions
    Last Post: 17-08-2010, 02:32 AM
