    I looked at the top common anode diagram and put a link to the manual.
    CNC4YOU confirmed he corresponding terminals on the HG08 breakout board.
    Blue wire is PULSE- and should connect to CK on the HG08
    Green wire is DIR- and should connect to CW on the HG08
    My next problem is getting 5v power to the board
    Hi edddy
    The board has a 5v point with 2 connection points mark with yellow dot in the picture I have established what I think is the 5V wire which was connected to the NCstudio board and marked 5v. Not sure which of the two points to connect this to on the HG08 board ? any help.
Name:	Breakout board HG08.jpg
    Quote Originally Posted by GeoDurie View Post
    Hi edddy
    Well the ones with the yellow dot are the power input and according to the manual it should be 7 to 55 volts, so 5v is no good, I would suggest a 24v supply.
    Here's the wiring diagram; http://cnc4you.co.uk/resources/CW504...%20Diagram.pdf
    Ok but didn't see that but still not the way I'd wire it.!! . Ideally we would like Differential outputs for best noise imunnity but we can't with this setup so next best would be Cathode IMO.
  1. 5v supplies for breakout board
    By dazza in forum General Electronics
    Last Post: 17-12-2014, 09:44 AM
  2. Breakout Board
    By Tomnewry in forum General Electronics
    Last Post: 12-12-2013, 07:24 PM
  3. Stepper Driver / PSU / Breakout board Wiring ?
    Last Post: 16-08-2012, 05:41 PM
  4. FOR SALE: PMDX-122 Breakout board
    By IN-WondeR in forum Items For Sale
    Last Post: 14-12-2011, 04:05 PM
  5. Breakout Board
    By croy in forum Electronic Project Building
    Last Post: 18-08-2011, 07:50 AM
