    i still seam to be having the same problem? i made the holes 3.2mm but it is not till i reduce the cutter to 2.6 that it seams to want to include them? any ideas is there another setting i have got wrong? I have attached the file hopefully it shows the setting. many thanks
    Attached Files Attached Files
    Sorry I can't open a cb file. ..Clive
    Quote Originally Posted by charlieuk View Post
    Because you need to use a drill operation for the holes.
    Ok I have just tried this with Aspire and a 3.01 circle and a 3mm end mill with an inside profile and in simulation it's fine ..Clive
    I have been routing all my holes this way for years. I wonder if Charlie is putting his cutter paths on the circle centre with no offset to the inside of circle? To my mind the problem will be in that direction. G.
    USE A PECK DRILL like Eddy suggested. Can't interpolate 3mm hole with a 3mm cutter simple as that.!
    That is why I suggested making the hole diameter slightly bigger and routing it out - this has worked for me for years!!! Of course if you have a drill cycle option that works fine as well. G.
    Quote Originally Posted by GEOFFREY View Post
    This is the bit I don't understand, why make the hole bigger if a 3mm hole is required ? Sometimes this will be fine but I'm sure there are more instances where the measurement has to be right.
    So what if there are say 166 holes.? Do you change ever piece of geometry.? how longs that going to take.! (Answer In this case would actually be to tell Cam tool is 2.99mm but hole will still be wrong size)
    What if the holes are for dowl pins and need to be exactly 3mm.? In this case a 3mm endmill won't work so again more time wasted swapping out endmills.
    Maybe I'm being a bit Pedantic here but Better to get into a habbit of using the easiest and less disruptive option which in this case would have been a Peck drill than changing geometry or using fudges like under sizing tools in Cam.
  1. Basic Frame Design
    By Ross77 in forum Machine Frames & Beds
    Last Post: 04-01-2015, 01:33 AM
  2. The ideal CNC machine for my (basic)needs?
    By mark84 in forum Machine Discussion
    Last Post: 12-03-2014, 10:56 AM
  3. NEW MEMBER: Basic 3d milling
    By proddy in forum New Member Introductions
    Last Post: 08-06-2012, 12:11 AM
  4. Advice on some basic tools
    By GTJim in forum General Discussion
    Last Post: 22-09-2011, 12:16 PM
  5. Which Basic Lathe
    By graysclassics in forum Milling Machines, Builds & Conversions
    Last Post: 06-07-2011, 10:39 PM
